Configure SAML with Microsoft Entra ID
This page provides guidance on configuring SAML with Microsoft Entra ID for Mattermost.
Tip
  • Need to configure Entra ID for OpenID Connect authentication instead? See the Entra ID Single Sign-On documentation for details.
  • See the encryption options documentation for details on what encryption methods Mattermost supports for SAML.
Before you begin
Prerequisites
  • A Microsoft Entra tenant containing applicable user data.
  • A verified custom domain for your tenant. See Microsoft’s Add your custom domain name to your tenant documentation for details.
  • A Microsoft Entra ID P1 or P2 license.
Set up an enterprise app for Mattermost SSO in Entra ID
  1. Log into the Microsoft Azure portal and select the Microsoft Entra ID service.
  2. In the left menu, select Manage > Enterprise applications.
  3. Select the New application button.
  4. In the Search application field, search for Microsoft Entra SAML Toolkit and select Microsoft Entra SAML Toolkit.
  5. In the Name field, enter Mattermost SAML then select the Create button.
  6. In the Mattermost SAML enterprise application settings, select Manage > Users and Groups to assign users and/or groups to the application or select Manage > Properties then set Assignment required? to No then select Save.
  7. In the Mattermost SAML enterprise application settings, select Manage > Single sign-on then select SAML under Select a single sign-on method.
  8. Select Edit in the Basic SAML Configuration section then set the below fields then select Save:
  • Identity (Entity ID): https://<your-mattermost-url>
  • Reply URL (Assertion Consumer Service URL): https://<your-mattermost-url>/login/sso/saml
  • Sign on URL: https://<your-mattermost-url>/login
  1. Select Edit in the Attributes & Claims section then set the below attributes:
  1. Set the the Unique User Identifier (Name ID) required claim Name identifier format and Source attribute values as required for your environment. Setting the Source attribute to an immutable value such as user.objectid is recommended.
  2. Edit claim names and namespaces under Additional claims to match SAML attribute settings you wish to set in Mattermost. Configurable settings are Email, Username, Id, Guest, Admin, First Name, Last Name, Nickname, Position, and Preferred Language.
  1. Select Edit in the SAML Certificates section. Select Sign SAML response and assertion for Signing Option and SHA-256 for Signing Algorithm then select Save.
  2. Select the Certificate (Base64) Download link in the SAML Certificates section. This is the Identity Provider Public Certificate to be uploaded to Mattermost.
  3. In the Mattermost SAML enterprise application settings, select Security > Token encryption. Select Import Certificate to import the Service Provider certificate. If you used the Bash script referenced in the Before you begin section, this is the mattermost-x509.crt file. The Import dialog says to upload a certificate with a file extension .cer, but .crt files are also accepted. Upload the file then select Add.
  4. Select the ... to the right of the imported certificate details, select Activate token encryption certificate, then select Yes to activate.
  5. On the Home page for Microsoft Entra ID, select the Overview link in the left navigation menu and copy the Tenant ID value. The Tenant ID will be used in Mattermost SAML 2.0 URL settings.
  6. In the left navigation menu, select Manage > Enterprise applications. Select the Mattermost SAML application then copy the Application ID. The Application ID will be used in the Identity Provider Metadata URL setting in the Mattermost SAML 2.0 settings.
Configure SAML Sign-On for Mattermost
  1. In the Mattermost System Console, select Authentication > SAML 2.0.
  2. Set Enable Login With SAML 2.0 to True.
  3. Set Identity Provider Metadata URL: https://login.microsoftonline.com/<your-tenant-id>/federationmetadata/2007-06/federationmetadata.xml?appid=<your-app-id>
  4. Select Get SAML Metadata From IdP to verify that the SAML metadata can be retrieved successfully.
  5. Set SAML SSO URL: https://login.microsoftonline.com/<your-tenant-id>/saml2
  6. Set Identity Provider Issuer URL (trailing slash is required): https://sts.windows.net/<your-tenant-id>/
  7. Choose the Identity Provider Public Certificate file from step 11 of Set up an enterprise app for Mattermost SSO in Entra ID then upload.
  8. Set Verify Signature to True.
  9. Set Service Provider Login URL: https://<your-mattermost-url>/login/sso/saml
  10. Set Service Provider Identifier: https://<your-mattermost-url>
  11. Set Enable Encryption to True
  12. Choose your Service Provider Private Key file then upload. If you used the Bash script referenced in the Before you begin section, this is the mattermost-x509.key file.
  13. Choose your Service Provider Public Certificate then upload. If you used the Bash script referenced in the Before you begin section, this is the mattermost-x509.crt file.
  14. Set Sign Request to suit your environment. The Signature Algorithm must match the algorithm set in Entra ID (RSAwithSHA256 is recommended).
Note
The Test single sign-on with Mattermost SAML tool in Microsoft Entra ID does not sign the request even if Sign Request is set to True in Mattermost. Depending on your security settings and key length, the Entra ID testing tool may successfully sign in while an actual sign in request from your Mattermost login page results in the error AADSTS90015: Requested query string is too long. since Entra ID handles the initial request with an HTTP GET redirect rather than HTTP POST.
  1. Set attribute settings to match attributes configured in step 9 of the Set up an enterprise app for Mattermost SSO in Entra ID section.
  2. Set the Login Button Text to suit your environment.
  3. Select the Save button.
Configure SAML synchronization with AD/LDAP
    If you don’t want to enable AD/LDAP sign-in, go to System Console > Authentication > AD/LDAP wizard, navigate to the Connection Settings section, then set Enable sign-in with AD/LDAP to false.
Once the synchronization with AD/LDAP is enabled, user attributes are synchronized with AD/LDAP based on their email address. If a user with a given email address doesn’t have an AD/LDAP account, they will be deactivated in Mattermost on the next AD/LDAP sync.
To re-activate the account:
Note
  • If a user is deactivated from AD/LDAP, they will be deactivated in Mattermost on the next sync. They will be shown as “Deactivated” in the System Console users list, all of their sessions will expire and they won’t be able to log back in to Mattermost.
  • If a user is deactivated from SAML, their session won’t expire until they’re deactivated from AD/LDAP. However, they won’t be able to log back in to Mattermost.
  • SAML synchronization with AD/LDAP is designed to pull user attributes such as first name and last name from your AD/LDAP, not to control authentication. In particular, the user filter cannot be used to control who can log in to Mattermost, this should be controlled by your SAML service provider’s group permissions.
Frequently Asked Questions
What encryption options are supported for SAML?
How to bind authentication to Id attribute instead of email
Configuring with an Id attribute allows you to reuse an email address for a new user without the old user’s information being exposed. For instance, if a user with an email address joe.smith@mattermost.com was once an employee, a new employee named Joe Smith can use the same email. This configuration is also useful when a user’s name changes and their email needs to be updated.
  • When the user tries to login and the SAML server responds with a valid authentication, then the server uses the “Id” field of the SAML authentication to search the user.
Note
Existing accounts won’t update until they log in to the server.
Can SAML via Microsoft ADFS be configured with Integrated Windows Authentication (IWA)?
Can I provision and deprovision users who log in via SAML?
Yes, but this relies on AD/LDAP to do so. Currently, we do not support SCIM. See “How do I deactivate users?” for more information.
How do I migrate users from one authentication method (e.g. email) to SAML?
How is SAML different from OAuth 2.0 and OpenId Connect?
