Install a license key¶
Available on Professional, Enterprise, and Enterprise Advanced plans
Cloud and self-hosted deployments
You can use the System Console or the mmctl tools to add or change a Mattermost license key.
Go go System Console > About > Edition and License.
Upload your license key file.
Once the key is uploaded and installed, the details of your license are displayed.
Use the mmctl license upload command to upload a new license or replace an existing license file with a new one. When complete, restart the Mattermost server. If you’re running in a High Availability environment, the new license file must be updated to every node.
mmctl license upload [license] [flags]
Note
From Mattermost v10.11, the option to add a license is disabled when the license is set using an environment variable.
Enterprise customers with the Premier Support add-on can request a staging license for testing.
Removing a Mattermost Enterprise or Professional license key won’t remove the configuration for Enterprise settings; however, these features won’t function until an Enterprise or Professional license key is applied.
When you’re using High Availability, it’s critical to ensure that all servers in the cluster have same Enterprise license properly installed to prevent multi-node clusters from failing. An Enterprise license is required for High Availability to work.
When you apply an Enterprise license key to a server previously licensed for Professional, Professional features retain their configuration settings in Enterprise.
When you apply a Professional license to a server previously licensed for Enterprise, Enterprise features retain their configuration but will no longer be accessible for use.
Change an existing license key¶
You don’t need to wait for your current license key to expire before replacing it with a new license from Mattermost. The server only checks for seat count and license end date, not the start date, so you can apply a new license as soon as you receive it. However, ensure your new license is for a seat count that’s greater than or equal to your current total number of Mattermost users.
Tip
To find the total number of users, go to System Console > Reporting > Site Statistics. The total number of users is displayed in the Total Activated Users field. The license will be rejected if this value is greater than the value allowed by your license key.
Follow these steps to change your license key:
Go to System Console > About > Edition and License.
From Mattermost v6.7, simply upload your new license key file.
Note
If you’re running a Mattermost release older than v6.7, select Remove Enterprise License and Downgrade Server to clear the license from the server and refresh the System Console first before uploading the new key.
License key storage¶
Once you’ve uploaded your license key to your Mattermost server, it’s stored in your SQL database at mattermost.Licenses
. You can check what keys are on your server by running select * from mattermost.Licenses;
Book a live demo or talk to a Mattermost expert to explore tailored solutions for your organization’s secure collaboration needs. Or try Mattermost yourself with a 1-hour preview for instant access to a live sandbox environment.
