System-wide attribute-based access policies¶
Available on Entry and Enterprise Advanced plans
Use this guide to create and manage organization-wide attribute-based access policies in the System Console. For channel-level rules managed by Channel Admins, see Channel-specific access rules.
Prerequisites¶
Attribute-based access controls (ABAC) require defined user attributes. First configure user attributes in the System Console.
Then go to System Console > System Attributes > Attribute-Based Access to enable attribute-based access controls for your Mattermost instance. This functionality requires a Mattermost Enterprise Advanced license.
From Mattermost v10.11, user-managed attributes are excluded from attribute-based access control (ABAC) rules by default for security reasons. This prevents access control policies from being circumvented by users editing their own profile attributes. To include user-managed attributes in ABAC rules, a system admin must explicitly enable the EnableUserManagedAttributes configuration setting. See the user attribute documentation for details on enabling this feature. This configuration setting is available only in Enterprise Edition Advanced and is disabled by default.
Define access control policies¶
You can add multiple rules to a single policy, and each rule can include multiple attribute values.
In the System Console, go to System Attributes > Attribute-Based Access and select Add Policy.
Enter a unique policy name. Parent access control policy names must be unique; if you enter a name that’s already in use, Mattermost displays a user-friendly error message and prevents the policy from being saved until you choose a different name.
Choose whether to automatically add users who match your configured attribute values as new members. Automatic synchronization is disabled by default.
True: Automatically maintains channel membership according to the defined rules as user attributes change.
False (Default): Only removes members and restricts adding them to the channel if they don’t match defined rules. Users are not automatically added.
Regardless of whether this configuration setting, users who no longer match the configured attribute values in the future will be removed from the channel after the next channel synchronization.
Define the attribute-based access rules to restrict channel membership.
Simple Mode is ideal for simple and straightforward access control scenarios. Each row is a single condition that must be met for a user to comply with the policy. Simple Mode only supports simple conditions without nested logic or mixed logical operators. All rules are combined with a logical AND operator
&&.Select Add attribute and select the attribute you want to use for access control.
Specify how you want the attribute to match the user profile. You can choose from the following options:
Is: The attribute must be an exact match of the value.
Is not: The attribute must not contain specified value.
In: The attribute must match at least one value.
Starts with: The attribute value must start with the specified value.
Ends with: The attribute value must end with the specified value.
Contains: The attribute value must exist somewhere with the specified value.
Specify the attribute values that users must have to be granted access to the channel.
Advanced Mode is ideal for complex access control scenarios that require CEL syntax to combine multiple conditions with logical operators that support rules like
user.<attribute> == <value>, using&&/||(and/or) for multiple conditions, and()to group conditions. The CEL Expression Editor provides real-time syntax validation and feedback, as well as context-aware autocomplete for attributes, operators, and attribute values.You can also start defining rules in Simple Mode and then switch to Advanced Mode to refine the rules further as needed. However, you’ll be blocked from switching from Advanced back to Simple Mode if one of the following are true:
Mixed logical operators are used between conditions.
Nested logic/grouping (parentheses) are present.
Unsupported operators or expressions are detected.
The syntax structure is
user.<attribute> <operator> <value>.As you type, autocompletes show available attributes. As you select attributes, autocomplete suggests appropriate CEL operators. After selecting an operator, when attribute values are pre-defined, autocomplete suggests values to choose from. Mattermost will explicitly indicate issues such as missing operators, incorrect syntax, or incomplete conditions.
Select the Validate syntax bar to check the syntax of your rule. If the syntax is valid, the bar will turn green and display a message indicating that the syntax is valid. If there are any issues, the bar will turn red and display an error message.
Simulate access¶
Select Test access rule to test the rule against your user base to return how many users would be granted access to the channel based on the current rule. Test your rules to ensure the intended scope and avoid unexpected access changes.
From Mattermost v11.8.0, you can use Simulate access to preview allowed and denied outcomes for specific users before saving policy changes:
Open the policy editor in the System Console.
Select Simulate access.
Choose the users you want to test.
Review the allowed and denied outcomes by action, such as joining a channel or uploading and downloading files.
Adjust the rules before saving.
Simulation can test draft policy changes before they affect live channel access or file permissions. Detailed rule and attribute information is shown only when the denial comes from the policy or scope you’re editing; otherwise, Mattermost may show that access was denied by another policy.
Note
Simulate access and channel-level permission policies for file upload and file download are gated by the PermissionPolicies feature flag (MM_FEATUREFLAGS_PERMISSIONPOLICIES) and require a Mattermost Enterprise Advanced license. See the Mattermost developer documentation for details on enabling feature flags in a self-hosted deployment. Mattermost Cloud customers can request this feature flag be enabled by contacting their Mattermost Account Manager or by creating a support ticket.
Manage rules¶
You can apply changes to existing rules or remove rules at any time using either Simple Mode or Advanced Mode. Select Save to save your changes.
Assign policies to channels¶
From Mattermost v11.8, system-wide policies can be assigned to both private and public channels. Select Add channels to search for and select the channels you want. You can assign the policy to multiple channels at once, or you can assign it to individual channels later. Select Save to save your changes.
The two channel types behave differently under the same policy:
Private channels are hard-gated. The policy adds matching users (when auto-add is enabled), removes non-matching members during synchronization, and prevents non-matching users from being added or invited.
Public channels are advisory. The policy never removes members and never blocks anyone from joining. With auto-add enabled it automatically adds matching users; with auto-add disabled the channel appears under Browse Channels > Recommended channels for matching users.
Before saving, you’ll be prompted to confirm the impact of the change so you can review how it affects each channel type.
Default channels (such as Town Square and Off-Topic), shared channels, and group-synced channels remain ineligible — they are excluded from the channel selector.
Note
Private channels with attribute-based access control policies can’t have guest users invited to them. Only users who match the defined attribute criteria can be added to ABAC-controlled private channels, ensuring strict adherence to access control policies. Public channels remain joinable by anyone regardless of the policy.
Delete policies¶
To delete a policy, select the Delete button next to the policy you want to remove. You can only delete policies that are not currently assigned to any channels. If a policy is assigned to channels, you must first remove it from those channels before you can delete it.
Define access controls per channel¶
You can assign an existing access control policy to a private or public channel for more granular control over channel membership. This is useful when you need to apply different rules for different channels.
In the System Console, go to User Management > Channels to select the private or public channel you want to configure, and select Edit.
In the Channel Management section, enable the Enable attribute-based channel access option.
Under Access policy, select Link to a policy to select an existing policy.
Once a policy is attached, the channel’s privacy can no longer be flipped between public and private until the policy is removed — see Channel-specific access rules.
Tip
You can also assign ABAC rules to a channel directly from a channel’s details page in the System Console under Channel Management by enabling the Enable attribute-based channel access option. Under Access policy, select Link to a policy to select an existing policy.
Remove channel policies¶
Disable the policy for the channel by selecting Remove Policy. You can then link the channel to a different policy if preferred.
Permission policies¶
From Mattermost v11.7, System Admins can define attribute-based permission policies that restrict specific user actions in addition to channel membership. Permission policies use the same attribute-based rules as access policies, but they apply to user actions rather than channel access.
Permission policies can be used to restrict the following actions based on user attributes:
File upload: Prevent users who don’t match the defined attribute rules from uploading file attachments.
File download: Prevent users who don’t match the defined attribute rules from downloading file attachments.
When a permission policy applies, users who don’t match the configured attribute values can’t perform the restricted action. Users may see file attachments as unavailable or redacted in messages they would otherwise have access to. See Restricted file attachments for the end-user-facing behavior.
Permission policies follow the same unique-name requirement as access policies: each parent permission policy must have a unique name, and Mattermost surfaces a user-friendly error if a duplicate name is entered.
